Home › Forums › Products › Stompboxes › H9 routing question › Reply To: H9 routing question
December 26, 2018 at 11:24 pm
#150888
bohan wrote:
H9 has a Dry/Wet routing mode, which can separately output dry and wet sound from 2 output ports. You can send the wet signal from H9 to your distortion pedal, and mix its output with H9’s dry signal. I think you may need another mixer/line switcher pedal or a pedal with 2 inputs to do this.
Yeah, I considered Dry/Wet but this would need another pedal since my distortion doesn’t have 2 inputs… Thanks for the reply!
