Home › Forums › Products › Stompboxes › Any info on the Power Max? › Reply To: Any info on the Power Max?
January 1, 2019 at 7:32 pm
#150902
Jman2089 wrote:
I just bought a powermax for my board. I do have a question. If I am correct even though it puts out 660 ma on a channel, but it should only draw the amps needed for those plugged into the channel correct? Example. Shure glxd 16 draws 250-400 ma. So it should draw only what it needs from the outlet. Yes? Or is it a constant 660. If it is I’ll have to make a return. Should have checked first
Unless the PowerMax operates very differently from all other PSUs, the rating can be considered a maximum load, the specific device plugged in will only draw what it needs from the 660
