Home › Forums › Products › Rackmount › H9000 Tempo for Note Value calculation › Reply To: H9000 Tempo for Note Value calculation
(Caveat – other will know more about this than I).
This is not a simple issue – parameters do not automatically respond to tempo changes unless they have been programmed to.
I don’t think you understood the issue.
I couldn’t upload enough screenshots.
On the box or emote, there is a drop down next to many time based parameter, e.g. whole note, etc.. that drop down always results in a whole note value that is based on 120bpm regardless of the machine tempo setting. It appears to be a bug.
Should I report these through the forum or email support? This needs to fixed as it’s a pain using external calculator for this for 6 delay lines.
