Home Forums Products Stompboxes Pre/Post Routing Noise Issue Reply To: Pre/Post Routing Noise Issue
#150944
bohan
ill_clinton wrote:
Thank you for the reply.
I connected the H9's the way you suggested and the noise was at a reasonable level and did not change when I toggled between PRE and POST.
Then I guess it might be your external stompbox's problem? What if you insert that stompbox into the Pre/Post loop? (Output 1 -> Stompbox -> Input 2)
