Home Forums Products Rackmount In/out routing option in options Reply To: In/out routing option in options
#150993
jbamberg
ndoe22 wrote:
I haven’t found a default setting in the preferences to do this. Maybe it will come with an update.
We are considering adding something like this in a future update – perhaps a "global IO" that isn't saved in the session, so if you have "global IO" assigned to your inputs and outputs, you can change session without affecting the routing.
