Home › Forums › Products › Stompboxes › Will Rose be available as an H9 alg? › Reply To: Will Rose be available as an H9 alg?
January 24, 2019 at 5:51 pm
#151088
AAgnello wrote:
… Sorry for the long post …
Please, no apologies. Your rare posts are always so detailed & informative.
AAgnello wrote:
… Rose is fundamentally different. It’s an experiment. It’s a left turn. It’s different. And, I love it. Now let’s see if anyone else cares.
You had me at “microseconds”.
https://www.eventideaudio.com/products/stompboxes/delay/rose
- Five customizable factory presets
- Analog Mix, Low Pass Filter, and Feedback
- Six tactile knobs: mix, feedback, depth, delay, filter and rate
- Invert phase flips the output phase with respect to the input phase for short delay times
- Reverse delay plays the delay line backwards
- Delay Multiplier increases the delay by either 2x, 3x, 4x or 5x
- Assignable HotSwitch: Tap Tempo, Delay Repeat, Mod Hold, Mod Reset, A/B)
- Multiple modulation sources: Sine, Square, Random, Envelope and External
- Expression / Auxiliary / MIDI TRS input
- Three different bypass types: Buffered, Relay, Kill Input
- Accepts Line or Instrument Levels
- The delay line’s clock can be swept over a wide range with delay time varying from .01 usec to 50 seconds.
