Home Forums Products Stompboxes Will Rose be available as an H9 alg? Reply To: Will Rose be available as an H9 alg?
#151158
skywriter
This sounds like the early rack mount digital delays from the 80’s by DoD, Ibanez, etc… although with some more advanced delay modulation waveforms other than sine/triangle. I still have several of these old variable simple rate devices around, which by the way, I agree sounds quite a bit better than fixed sample rate/DSP techniques – less aliasing and anharmonic artifacts.
