Home Forums Products Stompboxes Space Killdry off but no dry signal from Timefactor loop Reply To: Space Killdry off but no dry signal from Timefactor loop
#151160
knifey
Yes, my Timefactor knob is always set to 50%.
So – I just tried all 3 Bypass modes and the problem is still this: If (in Play mode) the Space is bypassed, I can hear the Timefactor loop playing, no problem. When the Space is active, I hear nothing when the Mix knob is fully counterclockwise. Is that normal?? I thought I’m supposed to hear the dry signal even when the pedal is active.
Thanks a lot.
