Home Forums Products Stompboxes H9 Midi Using Ground Control Pro – Load Preset Reply To: H9 Midi Using Ground Control Pro – Load Preset
#151304
joinpobob
Hi Nick, thanks for the quick reply.
I can get my Mobius by Strymon to work how I want it to.  (And I didn’t mention the competitor because I am a Eventide supporter; I did not intend “flawlessly” to be a cheap shot, and I only mention them to say that this isn’t some far-fetched idea that only I have thought of to implement.)
To get that to work, I send a MIDI CC Message of 102 (they call that “Bypass”).  So then if I have my GCP saved with the instant access button lit, it will send 127 value to engage the footswitch on the Mobius; if I have my GCP saved with the instant access button unlit, it will send 0 value to unengage the footswitch on the Mobius.  This works to load the preset and also works so that the light on the footswitch of the GCP always is the same as the footswitch on the Mobius.
Is this possible on the H9?
Thanks very much for your help.
