Home › Forums › Products › Stompboxes › H9 Performance Switch MIDI – Flip-flop Issue? › Reply To: H9 Performance Switch MIDI – Flip-flop Issue?
February 22, 2019 at 12:10 am
#151352
AndrewWhitfield
camn wrote:
Your midi is setup incorrectly. To properly use the performance switch via MIDI across all algos, your midi button should be sending 127 when pressed.. And 0 when released. Not 127 when pressed once, and 0 when pressed again. Youight be able to get partial function just by sending 127 every time. I detailed it more clearly here: https://www.eventideaudio.com/community/forum/stompboxes/performance-switch-over-midi-helix
Thank you Camn, appreciate it. I’ll give that a go.
