Home Forums Products Rackmount Using Emote plug-in with Logic Pro X – I/O setting? Reply To: Using Emote plug-in with Logic Pro X – I/O setting?
#151475
amop
macgee wrote:
That would be I
The plugin isn’t really much different. You’d still need to use I/O plugin to route audio back and forth unless I’ve missed something?
The benefit of using the plugin is that you can access automation parameters to modify algo using automation lanes and to save all session data, etc..
I’m busy making captions I’ll add to the video to explain things a bit. I’ll get it added tomorrow i reckon
Really appreciate that video. If nothing else it helped me resolve the issues I had making an aggregate device (which now works).
So when you use the emote plug-in (for the automations, etc) you still need the I/O plug-in to talk to the H9K?
