Home › Forums › Products › Rackmount › H9000 (OS 1.1) – DAW Automation, via Midi Controller, via Ableton › Reply To: H9000 (OS 1.1) – DAW Automation, via Midi Controller, via Ableton
Hello
i manged to get this happening via a Max4Live plugin called ControlChange8 that you can download here..
http://www.roberthenke.com/technology/m4l.html
that thing gives me 8 knobs which send CC data via numbered parameters that i can map into the H9000’s parameters. it does the job
one thing, one bug perhaps, if i draw automation data / curves etc into Ableton, this data is ignored, it doesnt play back / change mapped paramters in the H9000.
If i record myself physically editing the mapped parameters via a USB midi controller plugged into live and play back that data, things work as you would expect..
thx
