Home Forums Products Stompboxes H9 tempo clock to quick (>0.5 secs ahead on 60 bpm in 10 minutes) Reply To: H9 tempo clock to quick (>0.5 secs ahead on 60 bpm in 10 minutes)
#151853
jayron
    Thanks for your response Nick. In case there is no calibration option possible or considerable to be develop to manual correct the timing of the crystal what is an external option? (I mean, when I set the BPM manually equal to the BPM of the external click, I run into the same issue getting out of sync). Hope you understand my struggle expescially with the fixed BPM’s which are used with playing tracks along the live band.
    nickrose wrote:
    The tap tempo on the stompboxes is really designed for syncing up delays and modulation to the beat, and for this reason does not offer special accuracy. 0.5 seconds in 10 minutes is better than 0.08%, so it’s not all bad. This is plenty good enough for most purposes and cannot easily be improved.
    The MIDIclock output is timed by the internal crystal, not the mains frequency. Because there are only 24 MIDIclocks per quarter note, it is hard to get high accuracy. For this reason, a calibration setting would not be helpful.
    If you need greater long term accuracy, as it appears you do, you should consider an external precision source.
