Home › Forums › Products › Stompboxes › Can the H9 sum the two Mono inputs before effecting them? › Reply To: Can the H9 sum the two Mono inputs before effecting them?
February 16, 2020 at 4:08 pm
#154078
technically, the Looper ALgo, does Sum the L & R inputs to Mono to record the loop, and then doubles the Mono Signal onto the L & R channels, so this should be possible through firmware, but seeing the staff answer above does make sense too.
I really feel this might be possible though.
