Home Forums Products Stompboxes Using Expression Pedal with H9 Max Reply To: Using Expression Pedal with H9 Max
#154496
bohan
    Tim Zurowski wrote:
    Found a YouTube video that seems to have helped me with this. However, I am still having an issue with some of my presets though. They say "Expression Pedal mappings are disabled when the preset reads directly from the Expression Pedal".What does this mean? Why does it only happen with a few of my presets, but not all? I can't write the expression pedal settings if I cannot see it working in a particular preset.
    All parameters can be mapped to expression pedal. Do you use H9 Control? The ribbon and two buttons around it are used for setting up expression pedal mappings.
    "Expression Pedal mappings are disabled when the preset reads directly from the Expression Pedal" means that one of this algorithm's parameter uses the expression pedal directly, usually as a modulation source. For example, the PitchFlex algorithm uses the expression pedal for whammy effects. So the expression pedal is used for that in this algorithm. Another example I can think of is the Qwah algorithm, where the expression pedal can be set up as the source of modulation to make wahwah effect.
