Home Forums Products Stompboxes Master Volume Does not Work with Crushstation Reply To: Master Volume Does not Work with Crushstation
#154813
bohan
szabados1 wrote:
So the master increases the input to the send in the effects before the power amp. I have a Two Rock Bloomfield Drive Combo. When I look at the input and output meter on the Control, all other algo's have a match with an increase in master volume (input meter goes higher in h9) to output based on output meter in h9. On Crushstation, the master increases the input to the h9, but the output does not follow.
This makes sense cause there is a compressor and clipper in CrushStation algorithm.
