Home › Forums › Products › Rackmount › Does H9000 run hot? Can it be sandwiched between other gear in a rack? › Reply To: Does H9000 run hot? Can it be sandwiched between other gear in a rack?
September 4, 2020 at 9:17 am
#155701
tmoravan
I guess the question I’d have is — if possible, can you post the fan’s manufacturer/model number so we can at least look at the current specifications without having to open up a 9000 ourselves?
