Home Forums Products Stompboxes Timefactor – Can’t change parameters Reply To: Timefactor – Can’t change parameters
#156333
RussB
joecozzi wrote:
Hi Russ, if you’ve already updated the firmware, I also recommend conducting a factory reset. To restore Factory Presets and all System settings, power up TimeFactor while simultaneously pressing the Middle Footswitch and the Encoder until [INITIALIZING] is displayed. See if that fixes the functionality for you.
Hi, tried that also, before and after the update.  Same result, my control knobs are just for show.
