Home Forums Products Rackmount H8000 Routing and SP/DIF Reply To: H8000 Routing and SP/DIF
#156582
Jake Vell
    I see only one option that uses SP/DIF and that’s # 18. It also calls for using Firewire –
    I need to get a firewire cable that fits this connection
    I did discover that one Firewire channel is working. I assume I connect the Firewire to the TC Soundcard ?
    With the DSP 4500 it was easy to get SP/DIF connected and working. The advantage for me was, I could record and bounce VIRTUAL tracks easily in Logic.
    If I don’t use firewire and Sp/dif, Is there a way to use an analog set up in H8000FW and route that into a Digital Virtual track in Logic ?
    and therefore not need SP/DIF ?
    If So, How?
