Home › Forums › Products › Vsig and Preset Development › VSig Noob: I made an Emote crash loop › Reply To: VSig Noob: I made an Emote crash loop
January 1, 2021 at 11:09 pm
#156749
OK, that was a tricky one to figure out. You have two problems, one causing a crash:
1. your knobs *and* the objects they control are connected to the “basicMenu” menupage object. That is causing the crash (although, that should be filed as a bug).
2. your “statement” strings in the knobs are not correct. They need to be in %f form. $f for unformatted, %0.3f for zero-leading with 3 decimal places, etc.
I’ve attached a corrected sigfile.
