Home Forums Products Plug-Ins no metering showing in elevate Reply To: no metering showing in elevate
#156784
DGillespie
shanecgriffo wrote:
hi, i just bought elevate and there is no metering/levels showing in the big main meter box or on the limiter or transient windows when i play audio using elevate in Ableton 9 and 10..(tho it does show the inputoutput and gain reduction on the main input/output bars) Help!…  i imagine it's pretty useless without the metering 🙁
Hi Shane,
The scrolling and animated meters are drawn in OpenGL.  Can you try opening the SETTINGS page, turning the OPENGL button on and off, then closing and opening the UI?  Does this fix the problem?  Alternatively, does using VST2 instead of VST3 solve the problem for you?
Thanks,
Dan
