Home Forums Products Stompboxes Brand new H9 Core refuses to connect by Bluetooth. Reply To: Brand new H9 Core refuses to connect by Bluetooth.
#156857
bohan
You can see or change your pedal's Bluetooth PIN by:
1) Going to setting menu by long pressing HOTKNOB + the right footswitch
2) If you see BLUE, click the HOTKNOB again
3) Now you should see PIN, click HOTKNOB again
4) Now you can see the Bluetooth PIN. Turn the encoder to change, press the right footswitch to move digit.
5) You can exit the setting menu by long pressing HOTKNOB + the right footswitch again
