Home › Forums › Products › Stompboxes › Performance/hot switch activation by midi › Reply To: Performance/hot switch activation by midi
January 17, 2021 at 11:18 pm
#156899
MattDrago
camn wrote:
I would bet this is a feature, not a bug, Matt. If you sent the right signals, you get the right behavior. Probably I can help if you tell us exactly what you are trying to do…if your controller is suitably customizable. What controller are you using, and what messages are you sending?
I’m using an Akai Force with the midi out port to send midi to the H9. I assign knobs on the device to send miid CC to the H9, for example bypass I assigned to midi CC #5 and increment/decrement preset is assigned to CC #40 and #41. All other midi CC messages I have set up work perfectly on the Force without any issues.
