Home › Forums › Products › Stompboxes › H9 does not power up › Reply To: H9 does not power up
January 22, 2021 at 9:26 pm
#156925
It is possible for the power inlet connector to be damaged or the solder joints to be broken if it is treated roughly..
If the unit is under warranty, you may want to send it in, otherwise have someone who can use a soldering iron take a look at it.
