Home › Forums › Products › Rackmount › H9000 – mono sum dry signal path in summed algorithm? › Reply To: H9000 – mono sum dry signal path in summed algorithm?
Hi Ralph,
We are so happy to hear that you recieved your H9000!
So the issue is Mono In-Stereo Out. We are working to make this easier but as a work around right now here is what you can do:
-Go to the Expert Router once you are in the algorithms page in the H9000.
-You’ll notice that your input 1 is only connected to one input of your loaded algorithm instead of being connected to both inputs.
-From there, highlight the 2nd input of the loaded algorithm and press ‘Add’. This will draw a connection from your Mono-in of the FX Chain to the Input 2 of your loaded algorithm.
-This will now succesfully give you a Mono-in, Stereo-out signal flow
Hope this helps and if you have any other questions please email me at Pflores@eventide.com and i would be happy to help!
Have you guys implemented a way to do this that is easier, within Emote? I don’t see an option in any of the updates. I use this with a lot of mono gear (eurorack) so would be ideal to simplify the process. Thanks.
