Home Forums Products Stompboxes Midi chain? Reply To: Midi chain?
#157181
bohan
tenohr wrote:
I have a Gigrig G2 with a Strymon Timeline, a H9 and a Strymon Iridium in a midi chain. The Timeline and the H9 "talk" to each other via midi ch1 but it seems nothing passes through the H9 to the Iridium. I have done all the right settings on the Iridium and the H9 has midi thru as output. Tips, hints and tricks, anyone?
When you say "The Timeline and the H9 talk to each other via midi ch1" did you mean Timeline talks to H9? I assume your H9's MIDI output is connected to Iridium. However, Iridium doesn't have a 5-pin MIDI port. How do you connect your H9 to your Iridium?
