Home Forums Products Rackmount EMOTE Session partially not remembering parameter settings Reply To: EMOTE Session partially not remembering parameter settings
#157346
Hi again,
We've figured out what the issue you're having is and this appears to be bug.
If you load Two Reversedelays and don't make any adjustments to the master parameters, adjustments made to the secondary parameters will save/load correctly. However, if you make adjustments to the master parameters, when the algorithm is loaded the secondary parameters will snap to whatever the master parameters are. That is why you were having issue and I couldn't reproduce it at first; you had the master parameter set to 5000ms and I wasn't changing the master parameter.
So, a simple solution for you would be to just only use the secondary parameters and you'll be able to save/load instances of the algorithm correctly.
Let me know if that makes sense and if it works for you.
