Home Forums Products Stompboxes One 3-button switch, Two H9s Reply To: One 3-button switch, Two H9s
#157375
JES
Thanks for the volume tip.  Works perfectly and is very useful.
I think I’m doing something wrong on my pedal programming with the footswitch.
H9A is set to receive on channel 1, transmit on channel 2, MIDI merge so that program changes from another pedal will come through
H9B is set to receive on channel 2, transmit on channel 1, MIDI merge so that program changes from another pedal will come through.
I followed these directions and set the CC for the ring button to CC16, which is set to “hot switch” on both pedals.
I also set the ring to decrement preset on the “home” pedal so that I know it’s working.
I used one MIDI cable, so the output of one pedal is going into the input of the other.  I’ve tried H9B into H9A and vice-versa.  I get no response on the other pedal, but the preset is going down.  What am I missing?
Thanks.
