Home Forums Products Rackmount Eve/Net not working with two units Reply To: Eve/Net not working with two units
#157433
    I'm running out of ideas here.
    Can you confirm that neither Orville will drive the Evenet console without a fuse ?
    Note that you should be using the T1 fuses – these are slow blow. The F1 is more likely to blow on a short surge.
    In case it is a power on surge, might be worth looking for a 2A fuse.
    Or, try powering on the unit with the fuse first unconnected, then plug in the other parts one by one, just to see if it makes a difference.
