Home › Forums › Products › Stompboxes › Blackhole Pedal Locked(??)/Flashing LEDs….. › Reply To: Blackhole Pedal Locked(??)/Flashing LEDs…..
        March 20, 2021 at 1:33 am
        #157492
Make sure it’s highlighted in yellow and click “OK”.
It will take you to the main screen. Look for FIRMWARE UPDATES on the left hand side and click “Check for updates”. Click on the topmost choice so it highlights yellow and click “Install update” on the top right. You’ll see a progress bar, after which the pedal will reset. You should be good to go. Let me know.
