Home › Forums › Products › Rackmount › SOLVED: Orville Bad Check Sum and missing factory presets from bank 52 › Reply To: SOLVED: Orville Bad Check Sum and missing factory presets from bank 52
March 23, 2021 at 9:19 pm
#157508
jamie8286
After reading multiple posts it looks like its an issue with the U106 chip. I wiggled it around a bit and it solved it for a while, looks like it will be a solder job but hopefully that will fix the issue.
Cheers Jamie
