Home › Forums › Products › Rackmount › Coming from H7600 to H9000 › Reply To: Coming from H7600 to H9000
Thanks! Hopefully your will come sooner than that.
I seriously can’t believe this thing can do all that it can. I can route anything to anywhere. The flexibility is absolutely bonkers.
I’m aware of that the H9000 is the best multi FX gear the world has to offer. If you have unlimited time and don’t care about using warez, you can probably achieve almost the same results with plugins for no money. If you buy every plugin you need to replace the H9000, you will pay more in the end. If you have unlimited time, you probably never get your work done.
But: If you need to get your work done and you are serious, getting the H9000 is a no-brainer. I envy you today 🙂
In a case study of one, I cannot get the SP2016 plugin to sit as well as the H9000 version. I dont know why, I know its supposed to be the same. It’s just different.
