Home Forums Products Stompboxes Pitchfactor Reply To: Pitchfactor
#157690
bohan
darrenlovio wrote:
I have a Pitchfactor stompbox that I've had for 8 years or more that is now just constantly scrolling thru all the settings and not working. What can cause this and how can I fix this?
It sounds that the ribbon cable between the UI board and the mainboard is loose or need to be cleaned. If you open the case, you will see the ribbon cable. You can try to unplug it and replug again. Make sure it's clean and tight.
