Home Forums Products Stompboxes Setting a parameter with MIDI at program change Reply To: Setting a parameter with MIDI at program change
#157792
joecozzi
    Are you sure that the CC# programmed on the expression input of the MC3 correspond to the cc# assigned to the “Expression pedal value” on the H9? You could be sending CC#s that correspond to a specific parameter rather than the general expression/ribbon controller of the H9.
