Home › Forums › Products › Rackmount › H9000 2.0 is in Production › Reply To: H9000 2.0 is in Production
May 19, 2021 at 4:32 pm
#157878
joeydego wrote:
This was pretty straightforward and way better updating thru Emote!
Basically, not much different from the beta??
The production release fixed a small issue that would not allow H9000R units to connect via recovery mode using a direct ethernet connection. Besides that, it is the same as the 2.0 beta release.
Good to hear that the new update process worked well for you!
