Home › Forums › Products › Rackmount › Emote constantly crashes Cubase › Reply To: Emote constantly crashes Cubase
June 5, 2021 at 3:33 pm
#158032
I have experienced a similar, but not exact same issue, with Cubase PC and Emote. Happens both in standalone and plugin. Sometimes, loading presets / algorithms will cause Emote to crash / close. If I try to open back up, it will close almost immediately. When this happens, the only workaround is to restart the H9000. After doing so, Emote seems to work fine in both standalone and as a plugin. This behavior only happens with certain algos. I will try to pinpoint which ones are causing the issue.
