Home › Forums › Products › Plug-Ins › Linear phase option for SplitEQ? › Reply To: Linear phase option for SplitEQ?
November 18, 2021 at 3:16 pm
#160705
Sabralente
Cool! Thank you both. tbskoglund much appreciated for your reply, cool that you are thinking about the linear phase option.
hockinsk that surface dial looks interesting, probably not something I’d be into getting though. It’s true that you can drag horizontally using the band editor, it just feels a bit clunky if I lift the EQ, then need to go to the band editor to adjust Q and db, whereas in others it’s possible to use the scroll wheel for Q and then a hotkey for vertical axis – much more efficient.
