Home Forums Products Rackmount EMOTE / Error Message Sample rate annoying Reply To: EMOTE / Error Message Sample rate annoying
#161353
Hi John,
Thanks for your input. We’ve discussed this before, the pop-up system could be improved or an option to disable the USB audio driver could be useful so the error message doesn’t keep happening.
Just curious, what are you using the USB connection for if you are only using the analog I/O?
