Home › Forums › Products › Plug-Ins › All my plugins are crashing › Reply To: All my plugins are crashing
#161917
    Sorry for the issues you’re having. Please follow the general troubleshooting steps below and let me know if that resolves your issue:
    1. Confirm that you have the latest version of the plug-in installed: https://www.eventideaudio.com/products/plugins
    2. Confirm that you have the latest version of iLok License Manager installed (www.ilok.com).
    3. Make sure the plug-in license is activated to your machine or iLok dongle in the iLok License Manager.
    4. If you are using VST2, Eventide Plug-ins are installed to the following locations by default. Please make sure that your DAW is set to look at the applicable custom folder:
    -VST32: c:\Program Files (x86)\Common Files\Steinberg\VST2\Eventide\
    -VST64: c:\Program Files\Common Files\Steinberg\VST2\Eventide\
    5. If steps 1-4 don’t solve your issue, close your DAW and run the plug-in Uninstaller. The uninstaller is located at Start Menu->Control Panel->Programs and Features->Uninstall a Program
    6. Open your DAW and rescan you plug-ins, and then shut your DAW again.
    7. Deactivate and reactivate the plug-in license in iLok License Manager.
    8. Reinstall your plug-in. If you are installing VST2 to a custom folder, make absolutely sure you are installing the correct 32 or 64-bit version to that folder.
    9. Reopen your DAW and rescan your plug-ins.
    If you are still experiencing crashes, please upload a crashlog from Reaper and we can look into it.
