Home › Forums › Products › Rackmount › Fatal screwup h9000 :( › Reply To: Fatal screwup h9000 :(
February 2, 2022 at 4:24 pm
#161961
You should be able to recall your work using the DAW state restore with Emote in your DAW, but it is best practice to save everything as a Session as well.
The H9000 can save up to 900(!) sessions (the factory session numbers start at 901) but you can also save/load session to/from your computer by choosing “save” instead of “save to H9000” in Emote.
