Home Forums Products Stompboxes h9: AUX sw – program change question Reply To: h9: AUX sw – program change question
#162736
luedmo
Solved
Digitech FS3X has this written above the buttons:
  • TIP – MODE
  • RING – DOWN
  • T&R – UP
When I repeat that layout inside the H9, I got weird offsets, e.g. h9-1 ends up either 1 or 2 presets apart from H9-2 or h9-3.
One solution seems to be: keep TIP and RING separate (i.e. do not use T+R for UP).
  • TIP – DOWN
  • RING – UP
  • T&R – (e.g. Hotswitch or BYPASS etc.)
:L
ps: Having OUTPUT set to MERGE has no bad effect
