Home Forums Products Stompboxes h9: AUX sw – program change question Reply To: h9: AUX sw – program change question
#162737
luedmo
    Digitech FS3X weirdness #2…
    The FS3X is plugged into the h9-1 EXP port
    All 3 buttons are working good (DOWN, UP and P-SW)
    I attach another FSX3 to the h9-2 EXP port, just to see if to would work and…
    • TIP – gets a 100-0 readout on the H9-2
    • RNG – no effect
    • T&R – gets a 100-17 readout
    Looking closely at H9-2 in H9 control, shows that both switches get the same Hotswitch action. The funny thing is that pressing either the TIP or T+R results in a 0-100 behaviour, but… after you press TIP (once) T+R goes to the 17-100 behaviour
    Same goes for h9-3, so this does not appear to be anomalous to one h9 pedal.
    Perhaps this is not a bug, but a feature?
    :L
    ps: this whole thing is about trying to use multiple h9s to ‘morph’ presets using simple mechanical pedals like the digitech FS3X, and it sort of works…
