Home Forums Products Stompboxes Experience with TapeEcho ??? Reply To: Experience with TapeEcho ???
#163117
The filter in Tape Echo is a high cut filter, so at 100 you will be cutting a lot of high frequency from your signal.
Have you tried a low filter setting, or 0? This should allow you to use high feedback settings without the delayed signal sounding muddy.
