Home › Forums › Products › Stompboxes › H90 with Behringer FCB1010 › Reply To: H90 with Behringer FCB1010
December 10, 2022 at 3:42 pm
#167567
Yes, the H90 will respond to Program Change messages from your MIDI controller and recall the Programs you make. For example, you could create 5 Programs on the H90 using slots 1-5 on a user list. Then when you send a Program Change 1-5 from your controller, you can load any of those Programs. There isn’t much configuration needed to accomplish this, it should be easy to setup with your FCB1010.
