Home › Forums › Products › Stompboxes › H90 Tuner-How to set where it mutes › Reply To: H90 Tuner-How to set where it mutes
#167654
    Thanks for clarifying this.
    When using relay bypass, if the Program is first bypassed and you access the tuner, the audio will always pass thru even if you have selected mute. This will be fixed in a future update, but for now you can just keep the Program active when accessing the tuner if you’d like the audio to be muted while tuning.
    I’m assuming this is the issue you had because there is nothing else I can think of that would cause the tuner not to mute the audio. If you run into a different scenario where the tuner mute option does not work correctly, please let us know.
