Home › Forums › Products › Stompboxes › simple h90 question :) › Reply To: simple h90 question :)
December 30, 2022 at 12:43 pm
#168065
Hi willcrook69,
If you do not wish to use the User 1 default “factory” Programs as your starting point you can go into the System Settings under Global and switch the Playlist to User 2, which has all INIT Programs that are empty. Regardless, any time you load an algorithm it will populate with a factory preset. You’re free to crate you’re own and store presets and programs.
