Home Forums Products Stompboxes Create a preset in H90 with one of the two effects off. Reply To: Create a preset in H90 with one of the two effects off.
#168102
joecozzi
How could I turn the Hall algorithm initially off?
When you are in Select or Bank mode, the LED buttons on top of each footswitch can be used to select and activate or bypass the effect. In your case, bypass one effect, then save the Program in this state. Whenever you recall it, it will recall with that preset bypassed.
