Home Forums Products Rackmount Just got the H9000, what, if any, of my FX should I even keep? Reply To: Just got the H9000, what, if any, of my FX should I even keep?
#168209
joeydego
Sure. I’d record the BE100 head and the FAS BE100 model with no cab. I’d run both into two notes wall of sound at identical cab and mic settings. The results are too close to matter. The IR or the physical mic/cab has a lot to do with the final sound, probably more than the guitar amp itself. So using the same IR, the FAS stuff is in my opinion indistinguishable. I can’t hear a difference. Tested BE100, dual rec and slo100. A couple times I got ahead of myself and confused the tracks and wasn’t sure which was which.
