Home › Forums › Products › Stompboxes › Pitch flex with expression pedal › Reply To: Pitch flex with expression pedal
January 8, 2023 at 1:40 pm
#168362
Go back to where you programmed Heel & Toe A & B (for each of the four parameters). There is a 2nd page after the parameter – expression page. Turn the Select knob to access it. Set the START & END points with the Quick Knobs. Press Perform to confirm it.
