Home › Forums › Products › Stompboxes › Where to place my H9 in my pedal series? › Reply To: Where to place my H9 in my pedal series?
January 19, 2023 at 4:48 pm
#168535
Hey…Don’t turn those knobs on the POG up so much and that should fix it…Also you might wanna put the tuner first or have a buffer split at the beginning that sends signal to the tuner so it’ll work well when those other pedals are engaged
Thanks for the advice – I can certainly put the tuner first!
I’ll try not having the POG knobs so high; I don’t use the octave up function at all, but the octave down is a full, as is the dry signal knob. I use it when using the Diatonic algorithm – means I can play nice chords. I’ll try to find the right levels on the POG so that it doesn’t blast into the H9.
